09-10-2023
20:13
03:49
09-10-2023
20:13
03:49
My Fitbit Charge 5 was purchased in November 2022. It won't hold a charge. It will charge up to 100% but almost immediately drops to ~ 20% when disconnected from the charger. Can this be reset or does it need replaced. I bought it at COSTCO
Best Answer09-11-2023 03:53
09-11-2023 03:53
Hi there, @DDuaneR. Welcome to the Fitbit Community Forums. Thanks for the details provided in your post about the issue with your Charge 5. I'll be glad to assist you.
Before considering other options, I'd suggest to follow the recommendations listed in this article to improve or extend battery life. There are a few features that would make the battery drain faster than usual, even in one day. Some of these features are:
If this doesn't apply to you, another step that has been helpful for other users having battery draining problems is the three pulse restart procedure using the charging cable. This should also help with the problem you mentioned with the display:
Best Answer09-11-2023 05:48
09-11-2023 05:48
I did the restart process using the button on the charging cord - the fitbit "buzzed" and logo appeared briefly but did not come to life.
Best Answer09-11-2023 15:29
09-11-2023 15:29
How do I file a warranty claim for replacement? I purchased it at COSTCO.
09-12-2023 08:41
09-12-2023 08:41
Hello @DDuaneR
Since you're tried the recommended troubleshooting steps without success, you should contact Fitbit support. Click on this for links to contact them by phone, chat, or direct message: Fitbit support
You will likely need a copy of your Costco receipt for the warranty claim.
