Charge 5 won't hold a charge
Not only is my Fitbit not holding a charge but when I tried to use the ECG it says, Error and won't do anything.
3 REPLIES 3
Welcome back to the Fitbit community, @RainyRedeemed!
Sad to hear you're having issues with your Charge 5. As a first approach to hopefully get things fixed, I'd suggest restarting it. Before doing so you should make sure you've synced your device to not lose any data tracked so far. Also you should verify that the charging contacts on your device are clean and the charging pins on it's charging adapter are clean as well and can move flawlessly. In doubt, please have a look here:
How do I clean my Fitbit device?
Next please closely follow these instructions as timing is crucial for this procedure:
1.) Connect your Charge 5 to the charging cable which has to be connected to a reliable power source.
2.) Press the button located on the flat end of the charging cable 3 times within 8 seconds(!), holding each press for about 1 second(!).
3.) Wait around 10 seconds until the Fitbit logo appears on your device's display.
I'd like to point out that it sometimes requires more than one attempt to restart Charge 5. So, before throwing the towel, please give it another try.
I'll keep my fingers crossed.
Stefan
Charge, Charge HR, Blaze, Versa, Versa 2, Charge 5, Versa 4, Charge 6, Aria, Aria 2
Thanks for taking time to respond.  I ended up calling since the issue didn't resolve.  I still couldn't keep charge and the ECG still wasn't working.  I was sent an e-mail from warranty and am weighing my best option at this very moment.
You're welcome, @RainyRedeemed, thanks for reporting back!
Stefan
