01-15-2024 15:40
01-15-2024 15:40
Firmware and app is up to date. My device won't hold a charge more than a few hrs - literally charge up to 100% and then within a few hrs it's dead - this has happened 4 times now in the last 2 days so pretty much making it unusable.
This is sudden so not battery degradation - until this week I could go 5 days minimum without charging. There's not been any real changes in what I do and I don't have much in the way of constant notices etc Support asked me to do a 3 pulse reset and that hasn't helped at all.
Any advice?
01-15-2024 15:44
01-15-2024 15:44
I'd add seems there's plenty of people with a similar issue so suspect its a software issue despite what Fitbit assured me last night when I asked them
01-17-2024 03:01
01-17-2024 03:01
I have the same issue. Only thing left to do is to contact tech support, they told you to do what you've already done... Then they offered me a new device (same) for free or 50% discount on a different device. I am hesitant to get the same one if the problem is going to continue or to change to the Charge 6, but I'm not sure I want to give them more money. Not sure if the new one has the same issues...
01-17-2024 03:58
01-17-2024 03:58
Same problem here. I called customer service about this while it was under warranty and they told me to restart it and then charge it and use it while syncing it and get back to them. A week or two goes by and now it’s not under warranty. So I can buy a new one they advise. Yeah right. Great customer service.
01-17-2024 09:09
01-17-2024 09:09
Same. Just stopped working around 4 pm yesterday. I charged it up to 38%, enough to get through the night so I could use the alarm, but when I pulled it off the charger it was dead again. Plugged it back in and it restarted at 1%. I charged it overnight to 98% but as soon as I unplugged it, dead again.
01-17-2024 15:51
01-17-2024 15:51
Update - they are replacing it.
Seems to be a common issue unfortunately!
01-17-2024 16:43
01-17-2024 16:43
It yours still under warranty?
01-17-2024 20:44
01-17-2024 20:44
It was when I first reported the problem before Christmas but by the time they decided we had done enough trouble shooting it was no longer under warranty. Now they want to pretend like I never called in and reported it defective before the warranty ended. They just keep repeating that the warranty has expired. Also they are giving my a 50% off coupon for another fitbit. I just want this one to be warrantied as it just needs a new battery.
01-18-2024 11:36
01-18-2024 11:36
I also have the same problem. Am intermittently able to get it to charge but as soon as you remove it from the charging dock it’s dead! Managed to get it to start charging then started the suggested update.. left it to do its thing NOTHING, still dead!
01-18-2024 17:18
01-18-2024 17:18
That’s what mine does. It’s just black screen won’t do anything. I plug it in to charge but as soon as I unplug it it will immediately restart and go back to 0 charge.
01-18-2024 17:20
01-18-2024 17:20
No it was days after warranty expired. I suspect they know it is a common issue after the update hence replacing.
Best Answer01-19-2024 14:42
01-19-2024 14:42
I’m having the same issue with a watch I purchased 13 months ago. It is not covered under warranty. I can’t afford a new watch ever year.
Best Answer01-19-2024 14:44
01-19-2024 14:44
Same problem. Not covered by warranty. I can’t afford the price of a new watch every year.
01-19-2024 21:55
01-19-2024 21:55
Best Answer01-20-2024 04:00
01-20-2024 04:00
Mine failed 13 months after I purchased it at Costco. I did the chat thing twice. Both times I was told that it was under warranty. In the end I received an email saying it was not under warranty. I’ve posted about this before and my post has been removed.
Best Answer01-20-2024 04:08
01-20-2024 04:08
Same problem here. I wasn’t given an option. It’s out of warranty by less than 30 days. I wouldn’t give them any more money. I’ve replied to several posts and at least one of my replies has been removed.
01-20-2024 13:32
01-20-2024 13:32
Best Answer01-20-2024 14:21
01-20-2024 14:21
I am having the same issue of battery drain for the past 2 days. My watch was fine until their update. I am no longer under warranty and they had the audacity to give me links to buy a new one. I wonder how long they can keep this charade up for. If they can't stand by their product they've lost a customer in me.
Best Answer01-20-2024 16:55
01-20-2024 16:55
Best Answer01-21-2024 05:36
01-21-2024 05:36
Google thinks they are selling a watch when in fact all they have to sell is trust. Trust me when I say I’ll never be foolish enough to trust Google again. You can’t trust them.
