09-20-2024
12:57
11:19
09-20-2024
12:57
11:19
As of this morning, my Charge 5 has not synced after multiple tries!
09-21-2024 11:28
09-21-2024 11:28
Hi there, @CAR49ers. It's nice to see you around the Fitbit Community Forums. Thanks for bringing this to my attention and for the troubleshooting steps you've tried. I'm sorry to hear that your Charge 5 is still not syncing. I understand your concern, I will do my best to help you with this!
As a first approach, I'd recommend checking if your mobile device meets the requirements to properly operate with your Fitbit device. For more information, see Fitbit Compatible Devices.
In addition, please confirm if you've tried all the steps provided here Why won't my Fitbit device sync? in the order listed.
Best Answer09-21-2024 12:36
09-21-2024 12:36
Best Answer09-22-2024 02:46
09-22-2024 02:46
Thanks CAR49ers, experiencing exactly the same problems with my watch in Europe
Best Answer09-22-2024 13:28
09-22-2024 13:28
Hello @SPZ1684
There have been issues on the Fitbit side that affects data syncing and data discrepancies. The team is aware of the issues and have been working on getting the problems fixed.
For now, there's isn't any troubleshooting we can do on our side. Hopefully, it won't be too much longer before the problems are fixed and we see all our data properly syncing in the Fitbit app.
Best Answer09-22-2024 13:40
09-22-2024 13:40
09-22-2024 13:44
09-22-2024 13:44
Hi @CAR49ers
I, for one, will be watching for your daily updates. That will help me know when the team has fixed the problems and users are happily using their Fitbits again.
I'll be curious to see what your final invoice looks like. 😁
Best Answer09-22-2024 14:12
09-22-2024 14:12
Best Answer09-23-2024 11:13
09-23-2024 11:13
Tried just now to connect and sync again, seems to work again. Thanks to the team for solving the issue.
09-23-2024 11:16
09-23-2024 11:16
Hi @CAR49ers
I mainly focus on the Charge 5 & 6 and Pixel Watches. Based on what I'm seeing in those product help forums as well as the Android platform forums, the various issues are affecting multiple devices. However, it seems like not all the users of the Fitbit devices are affected in the same way.
I'm currently using a Pixel Watch 3 and am experiencing syncing and data discrepancy issues. So I understand the frustration.
The fixes for these recent issues can't come soon enough for all of us.
Best Answer09-23-2024 15:54
09-23-2024 15:54
Best Answer09-23-2024 20:13
09-23-2024 20:13
Best Answer09-25-2024 11:16
09-25-2024 11:16
There's an update for the Android Fitbit app, ver 4.26.1, that started rolling out today, 25 Sep 2024. I got the update this morning. Although I haven't seen confirmation, I'm hoping that this update fixes the data syncing issue.
The app updates tend to rollout in waves. If you don't see the update right away, keep checking.
So far, I haven't seen any posts about an update for iOS Fitbit app. I suspect one should be rolling out soon, if not at the same time as the Android app.
Best Answer10-20-2024 09:31
10-20-2024 09:31
Rieko, I am checking in to see if you have any updates on this issue. Based on a different problem I posted, I cleared my data and reestablished my account after doing a 'factory reset' on my Charge 5, which fixed that issue. Although I have not seen any posting that Fitbit fixed the syncing problem, my watch and app appear correct this morning! I will check it over the next few days, but if you do not hear from me again, you can assume the issue is resolved.
I appreciate the assistance over the past month.
Best Answer10-20-2024 11:48
10-20-2024 11:48
Hello @CAR49ers
Thanks for the update and letting us know that it seems your sync issue seems to have been resolved with a "factory data reset".
There have been at least 3 more Fitbit app updates since my last response. I wish there was more information for the updates other than "bug fixes and improved performance" for the updates. It does seem that there have been fewer reports of Fitbit syncing problems with the app after these recent updates.
I know there are still issues with some data syncing in the Fitbit app, especially exercise data for some users. Although I'll continue to monitor, hopefully, your issue is resolved.
It's been a pleasure to assist you. Thank you for your patience.
Best Answer10-26-2024 08:39
10-26-2024 08:39
Well, the issue appears to have been resolved this morning! Everything seems to be in sync! I guess that tech pushed out an upgrade that did not work, and after seeing the Community uproar over the syncing problems, they backed it out overnight, which would have been the correct approach. In any event, it looks like tech is on top of it now, at least for the moment. One small step for Fitbit, one giant leap for the Community. May the Force be with You.
10-26-2024 10:01
10-26-2024 10:01
Samsung A13, charge 5 ,nothing changed will not connect to phone. Google customer support could not solve
Best Answer10-26-2024 11:10
10-26-2024 11:10
Mine still is not working. Reinstalled app and restarted charge 5, unfortunately I had Uninstaller my tracker and now it will not connect to my phone
Best Answer10-26-2024 12:00
10-26-2024 12:00
