03-13-2023
17:44
13:08
03-13-2023
17:44
13:08
I am on my second Charge Five. Both stopped syncing with my android Lgk51 and will not sync. Is there an incompatibility issue with fitbit and phone? I cannot find a fitbit computer app for my charge five. Can anyone help?
03-13-2023 18:31
03-13-2023 18:31
Hi @Bellarella as of October 13, 2022, there is no Windows app. Read this article on the requirements for a phone - click to go there.
03-14-2023 04:00
03-14-2023 04:00
Thanks. An internet article gave a list of Fitbit compatible phones for Charge 5. Lgk51s listed but not Lgk51.
Best Answer03-14-2023 04:31
03-14-2023 04:31
@Bellarella Fitbit used to keep a list of phones that were tested by their engineers. Now it says that the app is compatible with most phones that meet the minimum requirements. Android 9 is the minimum OS for the Fitbit app. I think your should contact Support if your phone meets the requirements, but doesn't sync. I did a quick search that said that the LG K51 should meet the minimum.
Laurie | Maryland
03-15-2023 05:09
03-15-2023 05:09
Best Answer03-15-2023 14:47
03-15-2023 14:47
Finally, received an answer to the cause of my Charge 5 headache. My Lgk51 has an OS of 12. According to Fitbit support tech today all Fitbits require a phone with an OS of fifteen or greater. I do not remember seeing that in Fitbits compatibility guidelines.
Best Answer03-15-2023 16:03
03-15-2023 16:03
https://www.fitbit.com/global/us/technology/compatible-devices
03-15-2023 16:05
03-15-2023 16:05
@Bellarella as @LZeeW posted above, for Android, it's OS 9 or higher. I have Android 9 myself and it's working fine.
