07-18-2022
05:48
07:09
DavideFitbit
07-18-2022
05:48
07:09
DavideFitbit
My Fitbit won’t sync just states gathering data
Best Answer07-19-2022 07:08
07-19-2022 07:08
Welcome back to the Community forums, @RebeccaSuzanne.
I appreciate all the information that you've shared about the difficulty you're experiencing with your Charge 5.
Before considering other options, I recommend that you try restarting the device using the three pulse restart method described here below:
In addition to the restart, let me know if you already tried all the steps listed here to resolve syncing problems, and make sure to check the compatibility requirements listed here and to keep the Fitbit app updated to the latest version available.
Keep in mind that you need to sync through the Fitbit app and not through the Bluetooth settings on your phone.
Hope this helps, I'll be around.
