02-07-2023
17:50
05:11
DavideFitbit
02-07-2023
17:50
05:11
DavideFitbit
Why will my Charge 5 not sync? I’ve reset the device, deleted the Fitbit app from my iPhone and reinstalled, deleted the device from the app and reinstalled. Stool won’t complete the sync. It shows syncing, but doesn’t finish the process.
Moderator edit: format
Hi, welcome back to the Community forums, @HumpML.
I appreciate all the information that you've shared about the difficulty you're experiencing with your Charge 5.
Let me know if you continue to experience the same problem to sync your data. There was an outage a couple of days ago affecting some Fitbit services, but this should be resolved and you should now be able to sync. You can find more information about this issue here.
If the issue persists, please try the following steps that have been useful for other users:
In addition, I recommend that you try restarting the device using the three pulse restart method:
If you're still having any issues, let me know if you already tried all the steps listed here to resolve syncing problems, and make sure to check the compatibility requirements listed here and to keep the Fitbit app updated to the latest version available.
