11-17-2024
09:28
06:28
11-17-2024
09:28
06:28
The screen on my Fitbit Charge 5 stopped showing anything on November 15, 2024. I plugged it in to charge it, but the screen didn’t come on. I could tell that there was a connection because I felt the watch buzz when connected to the charger. First, I cleaned the receptors with rubbing alcohol. I spent the next few days trying to reattach it to the charger. Each time it buzzed showing it was connected, but the screen didn’t come on.
I purchased my first Fitbit in 2015. Since then, I purchased one on March 23, 2019, January 28, 2020, and February 14, 2023. I have had the current and 5th Fitbit not quite two years. I like the product, but I am frustrated with having to replace it so often. My mobile syncing device is my android phone. We got new phones in January 2024, and I am realizing that I never synced my Fitbit with my new phone.
Hi there, @Bomma. Welcome to the Fitbit Community Forums. Thanks for bringing this to my attention and for the troubleshooting steps you've tried. I'm sorry to hear that your Charge 5 is still not responding. I understand your concern, I will do my best to help you with this!
Please note that there are some issues that affect this, being which power source is used and how clean the contacts are and how well the charger is seated. If you are charging your Charge 5 on the wall socket, try using another CE certified USB adapter for low energy devices.
If you haven't done so yet, I'd recommend following the tips and recommendations provided here Why isn't my Fitbit device's battery charging?
Regarding the syncing issues, I'd recommend checking if your mobile device meets the requirements to properly operate with your Fitbit device. For more information, see Fitbit Compatible Devices.
If you haven't done so, please try all troubleshooting steps provided here Why won't my Fitbit device sync?
