06-11-2023
08:48
06:05
06-11-2023
08:48
06:05
It synchs with my phone but won't turn on, I just charged it so it's 100%. I don't have a cable with a button. So how do I fix this?
Best Answer06-12-2023 06:08
06-12-2023 06:08
Hi there, @Kmodek. Welcome to the Fitbit Community Forums. Thanks for the details provided in your post about the issue with your Charge 5.
If the restart recommended by @Gr4ndp4 doesn't work, try to change your clock face. If this fixes the issue, you can change your clock face back to the original clock face.
Best Answer06-12-2023 01:30
06-12-2023 01:30
Hi, @Kmodek welcome to the community, the button is on the USB end of the charging cable you are using to charge your Charge 5. This video demonstrates the process, do NOT factory reset as this will delete any data you have on the device.
I hope this helps but if you are still stuck please post here again.
Cheers
Gr4ndp4 | UK
06-12-2023 06:08
06-12-2023 06:08
