Hi, my new (last Friday) Charger 5 drains battery in around 24 hours
Example charged 100% and put it back on at 10.30pm last night and awoke at 4.30am, so 6 hours while sleeping the battery reading was 59% ... so 40% of power used while sleeping over 6 hours!
I've shut down everything I can find.
What's my next option here
Bought new direct from Fitbit plus a couple of bands so $350+
Best AnswerIf you have snore detection turned on, that is a big battery user. Unless you don't mind frequent charging, it is probably best used for just a few days to get a baseline. Then maybe try it again in a few weeks or if you have reason to think it is changing. I expect it is most useful for people who have no idea whether or not they snore.
19:25
18:13
YojanaFitbit
11-10-2021
19:25
18:13
YojanaFitbit
Eow!
Didn't know it had a snore detectir, where do I find that and how do I turn
it off!!!
It would pay to have a list of all apps and how much power they use & how
to turn them off
I'm fairly tech savvy & have been thru what I can find to disable
In a table of the Troubleshooting area of the website which by the wat
there is no Troubleshooting page identified in the manual???
Await your instructions
Regards
KBKerryn
Moderator Edit: Personal info removed
