11-10-2021
02:58
04:44
DavideFitbit
11-10-2021
02:58
04:44
DavideFitbit
Installed latest update, performed 2 ECG tests, got the feedback on the Charge 5, but on App it says I have yet to do a ECG.
also burnt through 20% battery in 8 hrs since downloading update
Feedback appreciated. 👍🏼
Best Answer11-10-2021 10:01
11-10-2021 10:01
I called Fitbit and they had me restart the device and then it appeared in the app. My battery dropped from 100 to 40 in one day
11-11-2021 04:43 - edited 11-11-2021 07:23
Hi, thank you for sharing your inquiry about the ECG feature, @Flykev.
Before considering other options, please make sure that you've tried the restart procedure, as @Sschriever mentioned earlier. You can find the steps to complete this procedure here.
In addition, if you're still not seeing any information in the app, please try the following steps:
@Sschriever Regarding the problem you mentioned with the battery. Let me know if you've followed the steps provided in this article, as they have been useful for other users as well.
Hope this helps, I'll be around.
