Charge 5 - is there a way to delete more than 1 ECG at a time?
currently I go to ECG, view history, select the result by tap on it, then press the 3 dots in upper right corner, select Delete result, then delete result.
this requires you to delete them 1 at a time. Is there away to delete multiples or setting that auto- deletes by age.
Hey there @Jbowen4646, thanks for stopping by. Allow me to help.
Since you are looking to delete more than one log, you may need to control your Fitbit data. See the link provided below the section "How do I delete my Fitbit health and wellness data?"
In some devices you many need to access as follows :
See if this instructions have helped you.
Best AnswerIt doesn’t appear that there is option related to ECG or Irregular rhythm notifications to delete the data under manage data.
Best Answer@Jbowen4646 I use an iPhone and followed the moderator's steps. The data list is long and is organized by type (Activity, Sleep. etc.) Please look in the Health Metrics section. I see both at the bottom of that section.
Laurie | Maryland
