Clock Faces for Charge 5
I know it gives some simple type instructions to look at a gallery of clock faces for Charge 5 but, I must be dumb because I don't get to any type of gallery at any point following those directions.
Has anyone downloaded a new clock face for Charge 5 and are you happy with the results? I f you would be so kind on directing me how to get where I need to be to choose a clock face, I'd be thankful!
1 REPLY 1
Welcome to the Fitbit community, @TrayceT!
There are two ways to get to the clock faces gallery. This is one of those:
First tap on your profile picture in the upper left corner of your Fitbit apps' Today screen. Next tap on the Charge 5 tile to select your device. Then tap on the Gallery tile and choose the Clocks tab in the upper portion of the display afterwards. Finally tap on the clock face of your choice and tap on Install to install it.
You could also tap on Discover in the bottom portion of the Fitbit app. Then scroll down to find the Clock Faces tile. Tap on that and then tap on the clock face you want on your device. Tap on Install to transfer it to your device.
In any case, please make sure that your Charge 5 and your phone are withing Bluetooth reach until the installation process is completed.
Stefan
Charge, Charge HR, Blaze, Versa, Versa 2, Charge 5, Versa 4, Charge 6, Aria, Aria 2
