08-03-2022
02:02
09:28
DavideFitbit
08-03-2022
02:02
09:28
DavideFitbit
After the latest update swipe left for notifications and then swipe right to
clock face, clock face disappears
fix is to reinstall a different face and then install the original one- this issue needs an urgent firmware update
08-05-2022
09:22
07:35
08-05-2022
09:22
07:35
Welcome to the Fitbit Community forums, @Lifer22.
I appreciate the information that you've provided about this issue.
That sounds a bit odd, let me know if you're only able to see a black screen when you swipe back to go back to the clock screen. In the meantime, please make sure that you've also tried restarting the device using the three pulse method with the charging cable and check if you continue to have the same problem afterwards:
I'll be around.
08-05-2022 14:58
08-05-2022 14:58
09-01-2022
06:50
07:34
09-01-2022
06:50
07:34
