Hello @HuyLuu
Out of curiosity, how did you change your goal to 5 miles? If you did this through the Fitbit settings in the app, that should have worked to change your daily goal.
Just brainstorming here. See if doing a force stop & clearing the cache for the Fitbit app on your phone works to keep your corrected mileage goal in place.
Hi RiekoC, thank you for your response. yes i changed the daily goal in the app thru Setting - Activity - Daily Activity.
How do i do a "force stop" and "clearing the cache"?
Appreciate your help.
Best AnswerHi @HuyLuu
I'm an Android user so I can provide directions for that platform. If you're an iOS user, you'll probably have to do a search for the directions.
For Android:
Hopefully, this works. If it doesn't, let me know. I will ask around and see if someone else has a suggestion.
Hi RiekoC, I cleared everything, disconnected & re-connected Bluetoothed, unpaired & re-paired the tracker. The 5-Mile/day on the Fitbit app is still there, but the dashboard still keeps resetting to 8.05 miles.
Thank you for your help!
Well that's disappointing to see that the app is still not updating with your change.
I'm going to ask around and see if someone can offer another possible solution.
Best Answer5 miles is 8.05 km, so I think the problem is not with the value but with the units. Ensure that you've selected imperial/US units in the Fitbit app and web site.
Hi Rieko and Peter,
Thank you for your outreach. In the App Setting, there are two choices for "Length". I picked Feet,Miles over the Kilometers.
