08-23-2024 15:51
08-23-2024 15:51
I set the sleep setting for Bedtime and wake time settings in Goals. I want to completely remove them since they appear to block the data graph of different types of sleep. How can I remove/delete them or other goals permanently?
Best Answer08-24-2024 02:39
08-24-2024 02:39
Hi, @pz77 , welcome to the community, you may find this article of interest How do I track my sleep with my Fitbit device? - Fitbit Help Center , it provides a comprehensive over view of the tracking process & advice. I apologise if you've already seen this. If you are still stuck after reviewing this article please post here again.
Cheers
Gr4ndp4 | UK
Best Answer08-25-2024 14:13
08-25-2024 14:13
Hello @pz77
To quickly see & manage your Sleep goals:
To see & manage all your goals in the Fitbit app:
I don't see a way to delete a goal once it's been set. It seems that they can only be edited/changed.
Can you tell us a little more about the issue you are seeing with your sleep graph? There could be a different way to help you.
