Display stays on
The display to my watch turns on and stays on randomly in the night. Anyone know how to switch it off? The “always on” Is turned off. Drains the battery very quickly.
5 REPLIES 5
Hi
Have you tried setting a sleep mode schedule on your Charge 5?
1. Open the Settings app and tap Quiet modes - Sleep Mode -
 Schedule - Interval.
2. Tap the start or end time to adjust when the mode turns on and
off. Swipe up or down to change the time, and tap the time to
select it. Sleep mode automatically turns off at the time you
schedule, even if you manually turned it on.
When the sleep mode setting is on:
  • Notifications, goal celebrations, and reminders are muted.
  • The screen's brightness is set to dim.
  • The screen stays dark when you turn your wrist.
To wake Charge 5, firmly tap the screen twice.
  • The sleep mode icon illuminates in quick settings.
Sleep mode turns off automatically when you set a
sleep schedule.
Community Council Member
Nathan | UK
Looking to get more sleep? Join the conversation on the Sleep better forum.
@Swil1967 - you could also put your charge 5 in sleep mode manically every night, then turn it off in the morning. Simply swipe down from the clock face and tap Sleep Mode. You may have to swipe a couple times. @N8teGee‘s suggestion will be easier in the long run but the manual method will let you easily try it out.
@Swil1967
Do you have Screen Wake set to Auto or Manual?  Auto will turn the screen on whenever you turn your wrist.
Gary D.| Feeding Hills, MA MBG PE
Pixel Watch 3, Pixel Watch 4
It’s on auto but the display turns on when I’m not even wearing the watch. It doesn’t look like the normal display with the clock, date and steps. It just shows the time. Sleep mode isn’t on either. It randomly happens, not every night.
I’m having same problem.  I’ve tried putting in sleep mode and still happened..
