Welcome to the Fitbit community, @Mattawan!
Please first check if Fitbit ECG is available in you home country by having a look here under "The ECG app is available on Fitbit Sense 2, Fitbit Sense and Fitbit Charge 5 in the following countries":
Check for atrial fibrillation with Fitbit
If so, I'd suggest restarting your device to hopefully get things fixed. Before doing so you should make sure you've synced your device to not lose any data tracked so far. Also you should verify that the charging contacts on your device are clean and the charging pins on it's charging adapter are clean as well and can move flawlessly. In doubt, please have a look here:
How do I clean my Fitbit device?
Next please closely follow these instructions as timing is crucial for this procedure:
1.) Connect your Charge 5 to the charging cable which has to be connected to a reliable power source.
2.) Press the button located on the flat end of the charging cable 3 times within 8 seconds(!), holding each press for about 1 second(!).
3.) Wait around 10 seconds until the Fitbit logo appears on your device's display.
I'd like to point out that it sometimes requires more than one attempt to restart Charge 5. So, before throwing the towel, please give it another try.
I'll keep my fingers crossed.
