09-21-2023
15:12
09:40
ManuFitbit
09-21-2023
15:12
09:40
ManuFitbit
I bought the charge5 mainly for ECG reading, I have it on my right wrist and readings started off fine. Now majority of the time it is giving me upside readings with the occasional correct way up.
Does anyone else have this
Moderator edit: format
Best Answer09-22-2023 09:46
09-22-2023 09:46
It's good to see you for the first time in the community @Janna1234
Thank you for sharing the difficulty that you are experiencing with your tracker.
I'd suggest you perform a restart.
Please, try uninstalling your ECG app and then re-installing it. To uninstall go:
Next return to your Gallery and apps, and then re-install the ECG app.
Sync your Charge 5 and confirm that the ECG app is back on your device.
