06-12-2022 21:34
06-12-2022 21:34
Hw do I set a "move alarm nuge" ??
Best Answer06-12-2022 21:40
06-12-2022 21:40
Hello @Bialun
Do you mean the reminders to move, 10 minutes before the hour to get 250 steps?
If so, from the Today Screen in the App on your phone, tap your profile picture, then Charge 5, then Reminders To Move. Tap to switch them to On and select the times you want them for.
Remember to sync your device so that it is able to vibrate to remind you.
I hope that helps you a bit.
06-12-2022 21:40
06-12-2022 21:40
Hello @Bialun
06-13-2022 06:24
06-13-2022 06:24
Thank you. I searched, not sure how I missed that. Appreciated.
