09-02-2022
09:03
09:12
DavideFitbit
09-02-2022
09:03
09:12
DavideFitbit
Is it safe to do charge it on a high WATTAGE? Is fast charging safe?
09-03-2022
09:12
14:12
09-03-2022
09:12
14:12
Hi, thank you for sharing your inquiry about the Charge 5, @iamCHESS.
I don't think fast charging would be a problem, but do you know what is the voltage that you want to use? It is usually recommended to use a UL-certified USB wall charger, or another low-energy device. You can find more details about this here as well.
Ideally, you would charge it using the computer, a TV, your car or similar.
I'll be around.
09-03-2022 13:24 - edited 09-03-2022 13:24
I have a 5v 3.1a output wall charger.
Is that good?
Or would that break my fitbit?
09-30-2022
09:49
14:11
09-30-2022
09:49
14:11
