06-12-2024 04:07
06-12-2024 04:07
Hi
I must say it is very annoying to notice charge 5 is dead when I try to use it. I never get a notification in the device nor phone to charge it or device has reached 10% or less (for example).
I charge it and I use to forget about it until I go to gym, etc. I've also set a home-screen where this data (battery level) is not shown by default.
It would be nice to have such config option in the phone or device to be alerted when battery reaches 10% or less. Did anyone solve this in other way?
Thanks
Best Answer06-12-2024 04:40
06-12-2024 04:40
@SunsetRunner There is a setting in the app that should help you. Please tap on you profile picture/gear icon > Notifications. This will take you to a page where you can set/manage certain push and email notifications. There is a Low Battery push notification option at the top of the push list.
The type of battery in a Fitbit doesn't "like" deep discharges. Try not to let your battery go below 20-25% for good battery health and longevity. Fitbit Wear & Care recommends limiting exposure to soaps, shampoos, and conditioners. I never wear my Fitbits in the shower and use that time to recharge the battery. It's good for your skin and good for your Fitbit.
Laurie | Maryland
06-12-2024 04:40
06-12-2024 04:40
Laurie | Maryland
06-12-2024 04:53
06-12-2024 04:53
Hey
Thanks for helping. I've went to Settings under my profile and found out that I've already enabled that option. After some deep reviewing seems I've disabled any kind of notifications for FitBit app under Xiaomi's HyperOS App Notifications setting. I've enabled it again so I hope this can work finally
Thanks again
