01-27-2024
23:50
13:53
LizzyFitbit
01-27-2024
23:50
13:53
LizzyFitbit
How many of you are experiencing battery problems since the update?
Could anyone who's experienced problems with the charge 5 battery please post once on this thread so it's easy to count and present to show it's not a warranty problem and is a result if the update.
I obviously have battery problems. Had to charge it twice yesterday and uninstalled the SpO2 app to try to make the battery last through the night. Managed to wake up to 50% battery instead of it being dead by morning, even though fully charged before bed.
Moderator Edit: Formatting and clarified subject
05-17-2024 14:50
05-17-2024 14:50
I put up with the charge for two days, after your stupid update. But when I went on a long-awaited hike today, I was very upset about a completely discharged device after 4 hours. Last year, with firmware 188.58, the charge lasted for several days. Stop fooling users already! Find the courage to tell the truth and set some deadlines for solving the current situation with your software!
05-17-2024 17:04
05-17-2024 17:04
I can't keep my Charge 5 charged. Went from 57% to completely shutting down. It wouldn't charge at first after being charged over night.
Finally got it to charge the second day. Lasted a few hours before dying again.
05-17-2024 22:42
05-17-2024 22:42
I’ve 2 charge 5. Since May 8th both are restarting again, not counting anything etc.
05-18-2024 04:19
05-18-2024 04:19
05-18-2024 06:01
05-18-2024 06:01
My oh my, what a coincidence!
05-18-2024 06:03
05-18-2024 06:03
Even if one we're to consider the Charge 6 after the Charge 5 fiasco, this should give one serious pause.
05-18-2024 09:11
05-18-2024 09:11
I am also having battery problems but it isn't as simple as losing charge. If I am still for half an hour or so, it switches off. It seems like the battery is dead but when I connect the charger it displays a high charge & also the time when it switched off. After a couple of minutes it displays the correct time & high charge. This is very annoying because it is missing chunks of my day & if it happens when I sm sleeping it doesn't re ird my sleep. Do fitbit actually read these posts?
05-18-2024 17:51
05-18-2024 17:51
My Charge 5 is also having battery problems. Used to go for a week, now less than a day. Screen goes black and it won't respond. Not counting steps. I've had it since November 2022, got it to replace 3 Versa ones that died, looks like this one is also doomed.
05-19-2024 11:22
05-19-2024 11:22
05-19-2024 13:12
05-19-2024 13:12
Same as my Charge 5
05-19-2024 17:21
05-19-2024 17:21
Also having an issue with the battery life of my charge since the recent firmware update.
The light on the back of the watch is constantly on, I suspect this is what is draining the battery so quickly. It lasts for maybe 5 hours. I've reverted back to a simple digital watch that will at least tell me the time.
I'm wondering if replacing the device since it's still under a year old, will help with the issue or is it for all Charge 5 since the firmware update?
05-19-2024 19:22
05-19-2024 19:22
OMG , I just went to my dashboard and it shows on my activity that I,ve walked 5264 steps today , my Fitbit charge 5 has been laying on kitchen table unplugged for past week . ugh what's going on with this thing ??
05-20-2024 05:44
05-20-2024 05:44
It might help as long as the new device you are sent still has the old firmware. From what other users have posted it seems Fitbit stopped the rollout of the new firmware that is causing the issue
05-20-2024 07:14
05-20-2024 07:14
Same. But just started this week.
18 months old.
getting the Fitbit logo.
need to charge for 4-5 hours to get 12 hours of use.
05-20-2024 08:08
05-20-2024 08:08
My battery is now lasting less than an hour. I’ve done all the recommended restarts/resets but nothing works. It’s just over two years old. Not sure what my next choice will be as I like the charge 6 design but reliability is worrying. I’m looking at changing to Garmin Lily.
05-20-2024 08:53
05-20-2024 08:53
Similar issue, same response!
Charge 5 losing charge quickly THEN screen wouldn't come on at all. Went through troubleshooting on my own then with a Fitbit tech. Nothing... Finally, they gave me the standard response, Out of warranty, here is 35% off a new one...
This would be the 2nd Fitbit I would have to replace shortly after the warranty expired. Frustrated at the thought of having to buy a new Fitbit every 2 yrs, I continued to troubleshoot on my own.
The last attempt, I went through the standard reboot/reset procedures but this time turned on my Bluetooth (something they did not suggest). Put it on the charger and the standard logo appeared now but was smaller and had a faint line under it. I realized it was trying to do an update.
Good news: after the update, it appeared to be charging again and screen worked.
Bad news: the battery is still dying every 24 +/- hrs...
I am looking for a new brand...
05-20-2024 09:15
05-20-2024 09:15
It's funny how the Charge 5 mysteriously go dead shortly after the warranty expires.
05-20-2024 09:21
05-20-2024 09:21
Same thing happened to me. I just got my Charge 5 around 14 months ago.
05-20-2024 09:51
05-20-2024 09:51
And only a few months after Charge 6 is released...
05-20-2024 10:52
05-20-2024 10:52
Agree, after the update it went from lasting 6-7 days to less than 24hrs. Researched, took out the Spo2 also, called support... nothing. Then the screen started blanking out (black) no response to touch or anything. Can sync, update the clock & will show active as it installs, and that is it. Goes black again. At one point the device got very hot during charging... Called support & they said out of warranty and offered a coupon. Well, after been a customer since (2017) Charge2 and my Charge 3 at least still works - unlike the 5 - it is time to say goodbye.
At a time it seems we are left with cheaper quality, updates that kill the device (maybe intended to force users to get new ones...) and sub-par materials and coincidently post warranty failures... it is time to cut the cord. It is a shame it's come down to this Fitbit! AND even with all the cases and recent complaints, we see where their focus is (not customer satisfaction and the quality of the product but increasing sales) ...! Not good!
Thanks for all the years of service, BUT these last few months just leaves too much of a bad taste to stay with you and your company!
