08-25-2023
09:47
10:50
RodrigoMFitbit
08-25-2023
09:47
10:50
RodrigoMFitbit
Worked fine until noon on 8/24. Now iit will not sync with Bluetooth. My other apps do. Was there an update? I already restarted twice. Thank you
Best AnswerHello @DUNNCL
There was a firmware update in July, but I think that might have been pulled. If you're on Android, there was a recent app update.
Hopefully, trying the troubleshooting steps on this page will get your device back in sync: Why won't my Fitbit sync?
@RiekoC Thank you very much for your help!
@DUNNCL Welcome to the forums. Thanks for reaching out about your Fitbit Charge 5 not syncing. I will be happy to help you with that.
I appreciate you taking the initiative to solve this on your own. There was indeed a recent app update and a firmware update too. Make sure your Fitbit App is up to date. I also recommend you take a look at the tips on the same article: Why won't my Fitbit device sync?.
