08-31-2022 14:00
08-31-2022 14:00
I've just returned from abroad and my fitbit is still on European time I've switched off my phone and restarted it and opened the app several times. Any suggestions pls
Best Answer08-31-2022 14:28
08-31-2022 14:28
Hi @Valah29. Have you double checked the location services setting? Your Fitbit needs location services enabled in order to sync with the correct time. I would check that. Also, you can try unpairing and repairing your Charge 5 to see if that helps as well.
Best Answer08-31-2022 15:11
08-31-2022 15:11
Hi Heather
Thank you, I ended up having to delete and reinstall the app again ! That's never happened before, , I'm aways popping over the channel and it always changes tge time back again 🙄
