09-01-2025
20:01
18:10
ManuFitbit
09-01-2025
20:01
18:10
ManuFitbit
Fitbit showing me sleep hours of two nights! Example showing I slept for 14 hours and says “This is your total sleep across 2 sessions”.
I need to see sleep for one night only.
here is a snapshot of the issue, where it says “this is your total sleep across 3 sessions.
09-02-2025 12:09
09-02-2025 12:09
09-02-2025 12:09
09-11-2025 18:28
09-11-2025 18:28
Hello, I was able to delete one sleep session since it is redundant.
However, I now have to delete it every single day. it is now stuck on recording two sessions.
What can we do about this ?
Thanks!
Khaled
09-12-2025 11:40
09-12-2025 11:40
Hello @KhaledZ
To me, it seems that something is going on with the Fitbit sleep algorithm where it's not correctly interpreting your sleep tracking.
You could try uninstalling and re-installing the Fitbit app on your phone:
Which version of the Fitbit app do you have? To check:
09-13-2025 00:08
09-13-2025 00:08
Actually, your screenshot that I see, is fine. One gives the basic sleep information, and the bottom one refers to the different sleep stages. If you delete the bottom one, you won't be able to compare how much "good sleep" you're getting. Mine does that sometimes when my "awake" period is over an hour long, even though I don't remember being awake. So I also actually have 2 sessions. I need to clean the back of my phone where the sensors are.
