Full charge. No display
Full charge but no display. Tried button push 3 times. Still No screen.
8 REPLIES 8
Having same issue. Charge 5 is logging data but screen is black
I am also having the same issue is there a way to resolve this
I have had this issue for over 3 weeks. Fitbit support say that they will be releasing an update to fix the problem
Mine just started doing the same thing this past Saturday. My phone shows its charged but but no display and I cannot seem to reset it.
I got it updated for the same issue , did NOT help resolving the black screen!  I even tried shacking the hack of it!!  hoping there is some problem with arm band motion sensor detection system also nothing apparently happened!
Update to this, battery dropped from full charge to 11% after 3 hours.
I contacted support on this issue. I put the Charge 5 on the charger anticipating questions and opened a chat with support. I moved the fitbit and the screen came back on just like normal, go figure. I asked the tech twice if he could tell when the device had last been updated but he ignored that part of both questions. I have no idea why it suddenly works.
This happened to me today, I thought because its was running low on battery - had 10% yesterday. I could not turn on the screen or do anything with it, then I launched the app and noticed that it synced with 98% of battery and that fw update is available. I had to restart my fitbit and app - still black screen, but i was then able to update the firmware.
Once the fw update was done, it came back to life but with no HR and autowake was not functioning. I went to check gps menu, it restarted automatically and since that everything is working.
Try to update it.
