Hi. Is it possible to retrieve the calorie counter icon on the main screen as I edited by mistake. It's the one below the zone mins. I have a charge
Best AnswerHi, @SunsetRunner , assuming you are talking about the app… to add (or remove) “tiles” from your screen just click on the word “edit” which you will find on the opening screen of the app on the right hand side below the banner and next to the word “Today”. In the edit screen you will see an X next to your existing tiles (to remove any unwanted ones). If you keep scrolling down to the bottom you will see available tiles that you can add.
You can also reorder them by putting your finger on them to drag and drop into a new position.
I hope this helps. Welcome to the forums!
