07-10-2023 01:06
07-10-2023 01:06
How do I stop the glucose reading notification prompt I get every morning. It isn't activated and I'm not diabetic.
I can't find out how to stop getting them
Best Answer07-10-2023 03:13
07-10-2023 03:13
Hi, @Kazzad , first you will need to have the glucose “tile” on your Today screen. If it isn’t there, on the opening screen of the Fitbit app, click on “edit” right hand side near the top. Find the glucose tile and click on “add” and then “done” to return to the Today screen. If the tile is already on your Today screen you can skip this step.
Next click on the glucose tile and click on the gear icon top right (next to the ?) then toggle the Reminder button to off (so that it is greyed out). Then you can return to settings and back to the Today screen. The reminders should stop!
If you would like to remove the glucose tile you can click edit again, click the X next to the tile to remove it, and then click “done”
Welcome to the forums!
Best Answer07-10-2023 04:38
07-10-2023 04:38
