10-27-2021
12:09
06:07
DavideFitbit
10-27-2021
12:09
06:07
DavideFitbit
I do the same bike ride every night and when I wear the Fitbit normally it only counts a couple active zone minutes. When I track the workout with the bike exercise app it states 20 to 30 minutes of active zone heart rate. There is a discrepancy here that is confusing. Is this a bug?
03-08-2023
07:16
19:57
EstuardoFitbit
03-08-2023
07:16
19:57
EstuardoFitbit
Welcome to the Community forums, it's good to see you around.
@Jenda @ForestHawk @charleskn Thanks for taking the time to share your experience with this feature. I'm sure it will be useful for other users as well.
Best Answer03-15-2023 03:54
03-15-2023 03:54
I'm experiencing the same issue with my Charge 5. I start the exercise mode for Weights and while standing still, the heart rate displayed on the device immediately starts climbing. For example, my Charge 5 currently displays a HR of 105 even though my actual HR is no more than 70. And like several others, when I end the exercise mode, I can see the HR gradually decrease down to an accurate reading.
I've tried this a few times now, and if I reboot the device, the HR will be correct immediately upon restart. But as soon as I start the exercise mode, it immediately starts artificially increasing. So, this is not a fluke or something that can be corrected with a restart. This is how the current version of the software operates.
I hope this will be corrected soon. In the meantime, it's clear that the exercise mode for Weights (at least) is so inaccurate as to be unusable.
Best Answer04-04-2023 19:53
04-04-2023 19:53
I have the same issue with my Charge 5 and its in all exercise modes. I use Walking, Elliptical, Weights, Interval..etc....they all do it. I could being doing cardio and measure my own HR and its 120....the Fitbit in Workout mode will show 160. Its ridiculous and frustrating. It obviously does not track my active minutes correctly either because those are based on HR which is wrong. If I dont use a workout app then the HR is closer to accurate. Reset does not work. I hope they fix this.....such a waste of a function.
Best Answer04-07-2023 08:55
04-07-2023 08:55
I'm 80 years old. I don't do heavy exercises anymore and don't ride bike but I do walk and I do a LOT of Tai Chi and Chi Kong (more than 10 years of daily routine). I notice the same discrepancies as many of you have documented. It seems that fitbit (Charge 5) exaggerates heart rate and consequently Zone minutes and calories burned when any of the exercise routines that are built for non-stepping activities are activated.
Since there is no routine provided for Tai Chi, I use the Yoga routine most often. If no routine is activated, none (or very little) zone minutes are credited. This is clearly misleading because the exercise provided by Tai Chi and Chi Kong is very, very beneficial to health and welfare of any individual and especially for the elderly.
I had a weight problem before I started using my Charge 5. I tried unsuccessfully to lose weight for 30 years. I believe my major problem was improper exercise routines (too extreme when trying to lose weight) and too extreme diet routines. Fitbit helped me lose 30 pounds in 4 months by helping me to adjust calorie intake and moderate exercise sessions. I found that for my adjusted exercise routine the calorie deficit computed by fitbit was about 750 calories too high to maintain a constant weight. When I maintained a daily calorie deficit larger than 750 calories I lost weight steadily. I found that a computed calorie deficit of 1000 - 1200 calories was a very good target to set for my calorie intake when trying to lose weight. It really worked very well for me. The 750 calorie number now holds my weight constant at my target. I love the Charge 5 now.
The 750-calorie deficit discrepancy when using the Yoga routine may, in part, be due to my age because metabolism tends to slow down after we reach retirement age - probably more than compensated for in the fitbit apps. I would suggest not using the number as a fixed rule but using the concept to help interpret your own experience with using the device and associated apps.
Best Answer08-01-2023 17:04
08-01-2023 17:04
I have a similar problem with my Inspire 3. I understand and accept that Zone Minutes estimates may vary depending on the workout mode selected (or not selected), as they each use different factors to estimate activity level. But I'm concerned that my heart rate measurements being off when using the Workout mode.
I spend 10 minutes riding into work on weekdays, and my heart rate is usually pretty steady at about 100. Today I accidentally activated a workout before I left for work, and 40 minutes later my Fitbit tells me that my HR's continuously been above 160 for the last half hour
Same goes if I forget to activate a workout at 6 PM and then wake up the next day: my heart rate and sleep quality estimates overnight are completely nuked.
Best Answer08-02-2023 07:57
08-02-2023 07:57
@jimjamslam wrote:I understand and accept that Zone Minutes estimates may vary depending on the workout mode selected (or not selected), as they each use different factors to estimate activity level. But I'm concerned that my heart rate measurements being off when using the Workout mode.
I'm not as understanding as you 🙂... I don't understand why the active zone minutes should depend on the workout mode.
My understanding is that this unit (Charge 5 for me) is supposed to have a heart rate sensor. To me, that means that it should be sensing my heart rate. In other words this should be a directly established number simply reporting what "is".
I've noticed the same as others - if you do the same regular physical exercise routine but just tell the fitbit you're doing a different exercise, then it seems to result in different zones...
BUT from what I observe this is because the reported heart rate was shown in those lower zones during the exercise - I was watching what heart rate it was displaying while exercising.
I try to do the same workout regularly each day, and normally use the "Workout" exercise, and was initially pleased to learn I was doing mostly cardio from this exercise!
But I've dug into the data and can see that the heart rate confidence levels buried in the data export are really poor during this exercise (typically confidence level 0 or 1). But the confidence levels when I'm running or walking tend to be OK (confidence=2). So I tried telling it I was cycling, but did my normal workout.
My heart rate was reported substantially lower - enough to go from allegedly mostly cardio, to now being only a small fraction of it reported as cardio.
This makes no sense.
It totally looks to me as though the Fitbit is taking into account what exercise you tell it you're doing when it tries to get establish your heart rate.
Which is nonsense! A heart rate sensor should be just that - a sensor - it should just report what your heart rate is from what it's seeing.
My understanding is that the heart rate zones should be just that - a measure of how long your heart rate is within a specific zone. This shouldn't make any difference what your associated exercise is - if you heart rate is in that zone, then it's in then zone, and it should be counted in that zone. Irrespective of what's caused your heart rate to be in that zone!
To me, my suspicion is that these units are just so poor at tracking heart rate that, imv, I suspect the fitbit heart sensor algorithm is taking into account what exercise you say you're doing, in order to try and better 'guess' what your heart rate is. Though I'm sure, if pushed, they'd probably phrase it the other way around by saying they're using the information to make it even more accurate 😉
A few BPM out I could understand. But the variation I see makes the difference between my regular workout being mostly cardio (65%+), vs mostly fat burn, with barely 10% cardio.
So I now have no real confidence which is correct. Is my workout giving me a good cardio workout, or only just a good fat burn? I have no confidence at all now as to what I'm achieving.
That's so far different that I question what the point of having the tracker is. At that level of variation I might as well just estimate calorie burn and heart rate zones from average numbers from the web for that type of exercise and just multiply by how long I've been working out. There doesn't seem much point having something getting in the way on my wrist when it gives such a wide variation.
Footnote: Heart Rate Confidence Levels
These are only embedded in the full data export - I haven't found them anywhere on the Fitbit app or website other than in the full data export.
They seem to be either 0, 1, 2, or 3. A confidence level of "0" seems to correlate with "--" shown on the Fitbit when you're exercising.
I have seen examples in my exercises where the confidence level is reported as "2" but the reported heart rate is just not believable - I mean I suspect likely >30 BPM out from what my actual heart rate likely really was at that moment. i.e. it says low end 'fat burn', but in practice in all other places for the same exercise (fast acceleration while cycling) I see it middle of cardio, and that would make far more sense.
I mention this because a confidence level of "2" on a scale or 0...3 might sound pretty good, but clearly it can still be substantially out - just because it claims to be confident, doesn't mean it's anywhere near correct 😊
The following is a plot of my heart rate on my most recent workout, taken from the data recorded using the "Workout" exercise program on the Fitbit and extracted from the data export.
(this is a custom analysis that I've done by quickly hacking together some software to perform an analysis on the fitbit data export - you won't find this view on the app or website)
The colors show the Fitbit unit's confidence level reported for each reading in my exported data.
Red = "0" - this shows "--" on the Fitbit display while exercising.
Orange = "1"
Grey = "2"
Green = "3" - this seems to be the highest confidence value that I've seen it report, so I presume the max.
The "Workout" exercise program for me almost always starts of with "--" on the display and confidence of "0" even if the unit was showing a heart rate on the home screen immediately before hand.
For a fitness tracker that I bought thinking it would give me a reading of my heart rate to better estimate calorie burn, etc, I'm bitterly disappointed. It really seems to struggle - and when even readings with a confidence level of "2" can be quite some way out, seeing much of my exercise recorded as confidence 0 or 1 does not inspire confidence (excuse the pun)!
When the promo videos for the charge 5 show people kick boxing wearing the fitbit, I expected that it would be a lot more robust and accurate tracking heart rate during a workout.
It's also curious how most of the red / zero confidence, tends to occur at the beginning of my work out. The more sweaty I get, and the more I get into the workout, the more confident the fitbit seems to get at measuring my heart rate. Which is at odds with other reports that suggest sweat can cause problems with the readings.
I suspect it's a reflection of how much it's using an 'algorithm' to try to analyse the senor data to arrive at a heart rate reading. Contrary to the impression they give about the great specific wavelength of light sensor, etc i suspect the input signal is very noisy, and they're in essence having to 'guess' half the time, and I suspect this is why they appear to be taking into account the type of exercise you tell it you're doing, and I also suspect there's an awful lot of averaging / smoothing going on.. by that I mean when it's struggling, it is probably looking at what the previous heart rate was when it was more confidence and biasing the current reading towards that, and things like that. .
But if those previous readings weren't all that accurate, then all that does is persist the inaccuracy. And I get the feeling that is happening quite a bit.
All in all, I'm not impressed. I thought the special wavelength HR sensor would have 'seen through' all the motion in your arms, etc. The more I'm seeing, however, the more I get the feeling that the sensor isn't anywhere near as good as they'd like us to believe at seeing the changes in your physiology associate with your pulse, and they're trying to make up for the shortfall algorithmically.
08-02-2023 09:54
08-02-2023 09:54
Thanks for sharing your detailed observations. I questioned the same thing a couple of years ago. But I think you nailed it. My heart rate is just different depending on my exercise setting that I choose. I've learned to live with it - but, like you, not particularly happy with that and not, ultimately, sure of my exact heart rate... Probably will end up switching devices at some point....
Best Answer08-02-2023 13:51
08-02-2023 13:51
I found out that the best measurement is best, when you just don't track any exercise, but just leave the auto track to do its job.
Very sad that Fitbit can't just do the obvious, which ls tl read your heart rate without doing any adjustments to it..
The same goes with the stupidity in run, hike or trail tracking, when the distance is measured based on your step length and not the GPS (which tracks the route exactly).
I really don't understand who leads the dev team at Fitbit,/Google.
If Garmin had such a small band with 7 days battery live, I would be long gone.
Best Answer08-02-2023 14:53
08-02-2023 14:53
@Jenda wrote:The same goes with the stupidity in run, hike or trail tracking, when the distance is measured based on your step length and not the GPS (which tracks the route exactly).
I've got a hunch why that might be...
Charge 5 - Built in GPS - Inherently very poor, or... - Fitbit Community
The built in GPS can be worse than the heart rate tracking.
Yesterday I did a walk and the GPS lost its connection for around 50% of the walk.
I've just done a longer walk today (overlapping in part with the route yesterday) and this time it tracked almost 3 miles without any connection dropout, apart from the first perhaps few hundred meters while it got its initial connection. It even got the details on the substantial section of the same route that it lost the connection yesterday, so it seems to be a fault with the unit rather than the environment or location. But from what is reported on line, built in GPS connection problems seem to be incredibly common with these units.
I'm tempted to contact support, but worried if I do, they'll send me a refurb replacement and then I'll get all the other problems of black screens or dud batteries or failed waterproof seals, that even more people are apparently experiencing. And it's not clear if anyone who has reported the same GPS issues has actually managed to get them resolved. A few have said the replacements that Fitbit sent had the same issues.
I'm staggered Fitbit aren't doing more to salvage their reputation with the Charge 5. This is my first Fitbit tracker, and it's likely to be my last. I'm making sure to let friends, relatives and work colleagues know how bad the device is, just in case they were ever contemplating getting one themself.
It's a shame - if it worked as advertised, it could be quite good. The features are just what I want, and I like the reasonably compact size, etc. But that counts for nothing if the core features just don't work dependably.
