01-15-2023
16:40
05:56
DavideFitbit
01-15-2023
16:40
05:56
DavideFitbit
When I'm on my tread climber, my Charge 5 shows 160bpm+/-, when I go to the app its only says I topped out at110bpm+/- and I'm not getting credit for peak. Anyone else have this issue?
Best Answer01-17-2023 05:55 - edited 01-17-2023 05:56
Hi, welcome back to the Community forums, @deadhorse.
I appreciate all the information that you've shared about the difficulty you're experiencing with your Charge 5.
As you mentioned earlier, it seems this could be related to a syncing issue. Before considering other options, I recommend that you try restarting the device using the three pulse restart method:
If you're still having any issues, let me know if you already tried all the steps listed here and check if you continue to have the same problem.
See you around in the Community.
