06-06-2022 16:40
06-06-2022 16:40
I swim with my family in a heated pool near our home and I was just wondering if it would be ok to wear my charge 5 while swimming. It is not a hot tub and does not reach temperatures of a hot tub.
Best Answer06-06-2022 19:50
06-06-2022 19:50
You should be able to wear it in a pool since the Watch is water resistant up to 50 meters.
06-06-2022 19:50
06-06-2022 19:50
06-06-2022 19:55
06-06-2022 19:55
I know I can wear it in the pool, I’m just concerned about the heat of the water possibly damaging my device
Best Answer06-06-2022 20:10
06-06-2022 20:10
I accidentally wore my Fitbit in the hot tub about 2 months ago and it is still working fine,
so since your going to wear it in a heated pool not a hot tub you should be fine.
But remember it is different for each person, I could have just gotten lucky when I wore my fitbit to the hot tub, but based on my experience,
you should be fine to wear the Watch to a heated pool
06-06-2022 20:13
06-06-2022 20:13
Oh and just a heads up, the Fitbit that I wore to the hot tub was the charge 4.
but since the charge 5 is newer it should be the same or even better than my watch at handling the pool
06-07-2022 03:12
06-07-2022 03:12
@BillyNeedsSleep The maximum operating temperature for the Charge 5 is 115° F or 45° C. I hope this helps.
Laurie | Maryland
