09-27-2022
07:02
05:41
09-27-2022
07:02
05:41
How to change charge 5 from manual to auto to tell time
Best Answer09-27-2022 07:23
09-27-2022 07:23
Hi @Lopol you can't. Time comes from the device you use to sync. As long as you sync more regularly, the time should be correct. There is no way to manually set the time.
