02-18-2024
05:02
06:33
02-18-2024
05:02
06:33
I need to know, step by step, how to remove my old failed charge 5, and install my new charge 5 seamlessly.
Hi there, @JemsJems1968. Welcome to the Fitbit Community Forums. Thanks for the details provided in your post. I will do my best to help you with this!
Before unpairing your old Fitbit device and setting up the new one, make sure that you've already synced your old Fitbit device so you avoid any data loss. Once done that, please try the steps below:
If you run into any issues while trying the above steps, please try the following:
Best AnswerHello @JemsJems1968
Although you should be able to set up your device according to Maria's instructions, I usually recommend deleting your old Charge 5 from the Fitbit app first. Then setup your new device in the app.
