02-17-2024
09:52
14:36
ManuFitbit
02-17-2024
09:52
14:36
ManuFitbit
On the screen, a fixed figure appeared, with a red circle with an X inside and nothing can be moved.
On the screen, a fixed figure appeared, with a red circle with a an X inside an nothing can be moved
problem solved
thanks
Moderator edit: clarified subject.
It's good to see you participating for the first time in the community @DocSMO @MStocks
Thank you for taking the time to share the information about this situation with your devices. I'm sorry to know the inconveniences.
Please, try to restart the device following these steps:
In addition, try to change the clock face as indicated in this help article: How do I change the clock face on my Fitbit device?
Best AnswerHello I tried this today but the logo never appeared. It’s does blank out. I have to tap it to wake it up. Is this a problem ?
Best AnswerThanks for your reply. I tried the reset process, after the 3rd button press, the Fitbit diamond logo appears and disappears after 2 seconds and the screen goes blank. I've repeated multiple times with no success. Any other suggestions?
M Stocks
