Hello @jtsorrell
How are you logging your exercises? Are you using Auto-Recognize or logging them from Shortcuts on your Tracker?
It seems strange they’re not logging properly. It might be worth trying specific shortcuts, if you’re not already, as you can have more control over logging times as you press Start and Stop yourself.
If you need to change the shortcuts on your Charge 5 to reflect the activities you do, you can do it from the App on your phone.
From the Today screen tap on your profile picture, then Charge 5. Tap Exercise Shortcuts then chop one you don’t use by swiping left to delete it and then tap +Exercise Shortcuts and add the one/s you want. Sync your Charge 5 to get it to show up on your tracker.
If the exercises you want to track don’t have shortcuts, using the generic ‘Workout’ or ‘Outdoor Workout’ might be a good idea. You could then edit the names later by selecting Categorize Exercise in the App.
I hope that helps a bit.
