I always have my Android phone with me, so the GPS is accurate, however I can't figure out if I am supposed to get a buzz on my Charge 5 for every mile. I set a 4 mile goal today and while it accurately displays the mileage, I don't get any notification per mile, nor when I finish my 4 mile run. Maybe it's not supposed to do it, but I can't tell. Any help is appreciated.
Best AnswerHello @exit30 and welcome to the Community. I don't have a Charge 5 on my account right now, but let me explain how this generally works. This is the way I'm reading your post. You used the Run setting on the Exercise app and set a 4 mile goal. When you use this setting, your Charge 5 will vibrate at your goal halfway point (you can set a different type of goal). If you want your Charge 5 to vibrate at every mile, you need to turn the Lap setting that is in the Run shortcut settings. When you choose Run, swipe up on the "^" at the bottom and look for the lap setting. On the Versa 3, there is an Auto count option and you tap on it and set your lap rule. I'm sure you have a similar setting.
Laurie | Maryland
