12-15-2022 10:26
12-15-2022 10:26
Have a new Charge 5. Under Notifications it says your "Wellness report is ready. Check it out" I click on 3 dots inside circle, then "Download PDF" My Samsung phone says "Downloading" but nothing further happens and there is no download.
Best Answer12-16-2022 23:33
12-16-2022 23:33
Hello @ATHiker9
Is it a new Wellness report you just generated or an old one generated some time ago ?
Best Answer12-17-2022 18:04
12-17-2022 18:04
Best Answer12-20-2022 06:54
12-20-2022 06:54
I think you need to generate a new report, and then download it and see if it works. I just tried using the same setup as you and it works fine for me.
