12-18-2021
05:54
12:38
EstuardoFitbit
12-18-2021
05:54
12:38
EstuardoFitbit
Just set up my charge 5 three days ago and I am not given credit for exercise although I have attended water aerobics
two of those three days. I previously had the charge 3 and got accurate credit for the aerobics exercise.
The steps taken and the calories burned seem to be accurate.
Moderator edit: format.
12-18-2021 15:43
12-18-2021 15:43
Hello @Donna47
Are you starting the exercise from a shortcut on your Charge 5 or letting automatic recognition work? It may not recognize Water Aerobics automatically if you're not really running about.
It might be an idea to set up an Exercise Shortcut so you can control the Start and End time, and tell your App you're exercising so it registers.
There are a couple of options here:
One is to set to Swim and then change later. If you choose Swim, the water lock automatically comes on to protect your Charge 5 from the water, which is great. A downside is that it can be difficult to disable water lock (you need to practice a bit before you need it) and that can be frustrating for some people as they find it hard to switch it off and stop their exercise session.
The other option is to choose another Exercise Shortcut, eg Workout and then change it later.
If you want to set up an Exercise Shortcut, go to the Today screen in the App on your phone. Tap your profile picture, then Charge 5. Tap on Exercise Shortcuts. There should be 6 already there. Choose one you'll never use, swipe left and choose Delete. Then a + Exercise Shortcut option should appear at the bottom. Tap that and choose Workout (or something else).
Sync your Charge 5 and it should show up under Exercise (you scroll up to find the other exercises).
Press Start when you're ready and Stop to finish.
When you've finished your exercise session, you can rename it in the App. Tap on the exercise session, at the top right tap the arrow to Categorize Exercise. Start typing Water in the search box, and Water Aerobics will appear as an option. Tap that and it will rename the exercise for you.
I hope that helps to solve your problem.
04-26-2023 09:43
04-26-2023 09:43
i had 29 zone minutes yesterday between 106pm and 123pm which exceeded my goal. mand the day before that i had 29 zone minutes between 415pm and 426pm which also excedded my goal. why didnt i get credit for exercise those 2 days, today i had 29 zone minutes between 1204pm and 1226pm and i did get credit. how can i correct the previous 2 days
