04-26-2023
09:42
12:38
EstuardoFitbit
04-26-2023
09:42
12:38
EstuardoFitbit
I am getting tired of having to keep reset my device when it wont sync!!! It wipes out all the data I had accomplished. This is not even a year old. and it's my 3 or 4th fitbit I've had in that many years. what is the best way to keep this from happening?
Moderator edit: format.
Best AnswerHi, @Mcaiello67 resetting your Fitbit should definitely NOT cause any data loss. This should only happen if you choose the option to delete user data - that is specifically designed for use when you are returning the Fitbit or passing it on to a new user.
A normal reset preserves all data. Instructions for reset are here .
Sync problems are not unusual and often resolve themselves in a few hours or less without any action from you. But I know they can be really frustrating!!! If you are in a hurry for a sync, I find the quickest way to force a sync is to simply log out of your Fitbit account and log back in again. A new log in should force a sync - but do be sure you know the email address and password of your Fitbit account,
Welcomecto the forums!
