06-26-2023 23:51
06-26-2023 23:51
All my problems started yesterday, which appears to be related to the latest firmware:
-White cross on red circle.
-Black Screen.
-Intermittent flashing fb logo.
-‘Settings’ tab not functioning.
-Battery draining in minutes.
-‘Apps synching’ displayed continually.
I can’t believe that the volume of similar problems on the forum are all unrelated.
I have tried all the various suggested actions to no avail.
I believe at this stage that fitbit have a problem with the latest software release and it’s implementation.
06-27-2023 02:12
06-27-2023 02:12
Hi, @Porridge51 welcome, assuming you have restarted your Charge 5 as demonstrated in this video & considered these suggestions How do I update my Fitbit device? without success, I recommend you talk to "Customer Support". Use the chat facility or phone for a prompt response. It's a good move to note the steps you've taken & the results so you can brief the agent accurately and allow them to understand your issue.
I hope this helps.
Cheers
Gr4ndp4 | UK
06-27-2023 02:12
06-27-2023 02:12
I hope this helps.
Cheers
Gr4ndp4 | UK
06-27-2023 12:10
06-27-2023 12:10
Thank you, yes I have done as suggested without success.
It all went downhill once the update started to download.
I’ll have a chat with support.
I was also interested in understanding whether others having these issues noticed any correlation with the update?
