09-27-2024
15:07
15:52
ManuFitbit
09-27-2024
15:07
15:52
ManuFitbit
Phone can't pair with fitbit. Says I need the app but I have downloaded it.
Moderator edit: clarified subject.
Best Answer09-27-2024 15:51
09-27-2024 15:51
Hi @TONROB. Welcome to the forums.
Thank you for providing the query regarding your Charge 5.
Please confirm that you are using the latest version of the Fitbit app. Please take a look at this help article: How do I use the Fitbit app?
I'd suggest following the steps below:
If you can't get started with your Charge 5, usually a missing requirement is the cause. Carefully review the requirements provided in the help article Why can't I set up my Fitbit device?
If you continue having syncing difficulties after linking your Fitbit device, please see Why won't my Fitbit device sync?
Best Answer09-30-2024 07:16
09-30-2024 07:16
I have done all of this and it is still stuck with the Fitbit logo flashing
Best Answer09-30-2024 09:21
09-30-2024 09:21
Hello, my Fitbit is completely unresponsive since last night. The screen is black. I tried everything listed above, and also did a restart by pushing the charger cord button 3 times (which usually works when it won’t sync).
