04-27-2022 10:57
04-27-2022 10:57
Quick calorie add now accepts input but fails to log or display.
Best Answer04-27-2022 11:16
04-27-2022 11:16
Hello @donjblythe and welcome to the Community. You are describing an app issue. Do you use an Android or iPhone? Your post can get moved to the correct forum. It will help bring attention to this issue.
Laurie | Maryland
04-27-2022 16:45 - edited 04-27-2022 17:00
Hello @donjblythe
I think I might know what your referring to when you say quick calorie add. Try this:
go to your Fitbit App Today Page > Go to Food Tile > tap the Plus Sign > Now tap directly on the numbers '123' on top left of your screen> type calorie amount you wish> now tap save.
Hopefully this is what your looking for. I just created a quick calorie for myself to ensure it would log correctly and it did. If yours doesn’t try logging out of the Fitbit App and then log back in again. I hope this answers your question. 😃 Happy Stepping!
