10-26-2022
21:04
10:06
DavideFitbit
10-26-2022
21:04
10:06
DavideFitbit
I keep single tapping on the screen wake but it will not change from Manual to Auto. The same things happens for DnD. But the other options like Sleep mode will toggle with a single tap.
Any ideas?
Best Answer10-27-2022 10:06 - edited 10-27-2022 10:07
Hi, welcome to the Fitbit Community forums, @MenAm.
Thanks for sharing that you've been having this inconvenience with your Charge 5.
That's a bit odd, I've tested this on my Charge 5 and it should change from Manual to Auto with a single tap. If you haven't done so already, please try completing a three pulse restart and let me know if you continue to experience the same behavior:
I'll be around.
Best Answer10-27-2022 13:52
10-27-2022 13:52
Thanks for replying @DavideFitbit
That didn't work. But the more I look at my watch, it looks like the option is disabled. Is there a place to enable/disable options?
Thanks again.
