11-27-2022
02:16
06:32
DavideFitbit
11-27-2022
02:16
06:32
DavideFitbit
Hi, I have had my Charge 5 for a couple of years now. Recently, my screen started displaying the ecg app and I can’t swipe / tap back to the clock face. Is there a simple to get rid of the ecg screen flashing screen so that I can use the other features on my watch? Thanks! 😀
Moderator edit: format
06:32
06:35
11-29-2022
06:32
06:35
Hi, welcome to the Fitbit Community forums, @Salfran.
I appreciate the information that you've shared about this inconvenience with your Charge 5.
That's a bit strange, you should be able to go back to the clock screen by swiping right on the screen. If you haven't done so already, please try completing a three pulse restart using the charging cable and check if you continue to experience the same problem:
I'll be around.
01-11-2023
21:54
08:41
DavideFitbit
01-11-2023
21:54
08:41
DavideFitbit
My charge 5 is stuck like this right now. I had it in my pocket so that it would register steps while I pushed a grocery cart. There are no buttons on my Fitbit and pushing the sides to take an ECG reading does not change it.
Thanks, I found the button. The cord is plugged into a clock on my nightstand and I never realized it was there on the USB end. Pressing it did not work but later the heart screen popped up and I was able to get back to the time screen.
08:41
06:35
My Fitbit Charge 5 gets stuck when I try to use the ECG. I can swipe to the screen, the instructions flash, I put thumb and forefinger on the side. The directions continue to flash and flash. No result’ and then the screen freezes there. It takes about 2 minutes before I’m able to swipe back to the home page of the clock face.
grrr. Help?
@Mumzyfit Thank you for confirming that you've been having a similar problem.
Could you please also confirm if you continue to experience the same issue after the restart procedure mentioned here earlier? If the issue persists, please try the following combination of steps:
