04-27-2022 12:33
04-27-2022 12:33
When I activate sleep mode or dnd mode charge 5 does not vibrate even though I have activated the always vibrate option.
What is the purpose of that option if it does not vibrate always?
Everything else works fine, except vibrations on this modes.
Any thougts on this?
Best Answer04-27-2022 14:48
04-27-2022 14:48
I had never noticed that setting before.
That "always vibrate" setting looks like it refers to the phone sending the vibration signal to the tracker, even when the phone is in DND mode. But despite the phone sending the signal, the Fitbit settings such as DND and sleep mode will override that. I guess the reason that option is there could be if you have the phone set to silent or dnd so you won't be interrupted by a loud ringer, but you still might want the vibration on your wrist.
If you are in a meeting, you might want phone on silent or DND, but still want wrist to vibrate, but if sleeping, might not even want wrist vibration.
Does that make sense?
04-27-2022 14:01
04-27-2022 14:01
Where did you find "always vibrate" option?
Best Answer04-27-2022 14:32
04-27-2022 14:32
In the Fitbit app -> charge 5 -> notifications.. Picture
04-27-2022 14:48
04-27-2022 14:48
04-27-2022 15:05
04-27-2022 15:05
I see, and yes I aggree now, because it does send vibration to band when phone is on silent. Thanks!
