02-07-2023 07:06
02-07-2023 07:06
The sleep hours are not appearing. I've tried logging out and back in, but still not showing?
Best Answer02-07-2023 07:15
02-07-2023 07:15
There is a massive outage of Fitbit servers currently, the issue is not solved. Everybody has problems right now. Please be patient and wait until the engineers fix the server problem.
Best Answer02-07-2023 07:14
02-07-2023 07:14
Same here. My Charge 5 won't sync - its showing steps & calories but not the sleep hours. I ran through all of the trouble shooting options on their help page and it's still not working. I checked out their twitter and it looks like many people are experiencing issues. I've messaged them on twitter to see whats up.
02-07-2023 07:15
02-07-2023 07:15
Best Answer02-07-2023 08:31
02-07-2023 08:31
I spent a long time following all of the steps this morning to reset everything, restart everything, relink, and when I finally called Fitbit support, I was told that the problem is on there and and that I should try later today. It would have been nice if they had reached out to us and let us know not to spend all the time following all of their troubleshooting steps. They certainly know how to retest through email anytime they want to sell us something, so they could have sent an email telling us that there was a problem on their end.
02-07-2023 08:46
02-07-2023 08:46
@jan72361 If they have server problems, most likely they can not send e-mails.
They actually did let you know, there is a banner at the top of the forum which was put in place very quickly. Look at it for status updates.
Best Answer02-07-2023 09:12
02-07-2023 09:12
same here--did the "update" and didn't help either....
02-07-2023 22:13
02-07-2023 22:13
There is no banner there now and I still have dodgy data!
02-12-2023 10:37
02-12-2023 10:37
Ok .. That is the best. I hope it has nothing to do with the Chinese Spy Balloon that was over my house South Carolina!!
Thank You
Best Answer02-14-2023 13:35
02-14-2023 13:35
I'm still having problems. Do we know when this is likely to be fixed? Or, if the server problem has been fixed, is there anything I need to do to reset?
Best Answer02-15-2023 02:29
02-15-2023 02:29
@Rosw2 Could you please describe what are the problems you are having ?
Best Answer02-15-2023 12:58
02-15-2023 12:58
I have a Blaze. For the past week or so my sleep is not being tracked at all: no start/finish times, no sleep statistics of any type and no sleep score. The app allows me to add a log but that just produces one dark blue line, no break up of rem, deep etc.
Best Answer02-15-2023 13:01
02-15-2023 13:01
There is no banner showing for me, so no way to see status updates.
Best Answer02-16-2023 02:31
02-16-2023 02:31
The outage is finished, so your sleep not showing is not linked. Have you tried the normal steps:
- did you restart your Blaze ?
- did you change the Sleep sensitivity settings ?
- are you ensuring you are wearing it tight at night ?
02-17-2023 06:19
02-17-2023 06:19
Best Answer02-18-2023 07:42
02-18-2023 07:42
Thanks @SebWotan. I hadn't reset my blaze - have now done so and the issue appears resolved. Thanks so much for your help!
06-21-2023 16:07
06-21-2023 16:07
has this been resolved? My Verse 2 is not tracking my sleep or heart rate.
