I just got my Charge 5 last week. I wanted to add indoor cycling or spinning as an exercise.option, but it's not available for the Charge 5. What are other people using to track their indoor rides? Les Mills Sprint and RPM are my favorite group fitness classes at my gym.
Best AnswerHello @MEMcCord
You can have up to 6 exercise shortcuts on your Charge 5 and one of the choices is Spinning. To get it, go into the App on your phone, tap on your profile picture, then Charge 5.
Scroll down to Exercise Shortcuts, choose one you want to swap, swipe left to delete. Then you have + Exercise Shortcut at the bottom. Scroll through those and you can find Spinning. Tap on it to add. Then sync your Charge 5 and it should show up under Exercise on your tracker. You scroll through those to get to the one you want.
You can always delete shortcuts you don't need and delete and add on the App to bring the ones you use the most to the top.
I hope that helps.
