12-27-2022
08:26
06:04
DavideFitbit
12-27-2022
08:26
06:04
DavideFitbit
How do you set Charge 5 to swim mode like it mentioned in set up to let it know that you are swimming as it mentioned you need to do this before swimming
what does the icon look like ?
Moderator edit: format
Best Answer12-28-2022 06:04
12-28-2022 06:04
Hi, welcome to the Italian Community forum, @Bootz4.
Thank you for sharing you inquiry about the Charge 5.
You can find more details in this article on how to add a specific workout to start it directly from the device. Note that you can only select 6 workouts at the same time on your Charge 5 at the same time, so if you currently have 6, you'll need to remove 1 of them to add the desired workout:
Fitbit app
In addition,. you can also automatically track swims to capture pool lengths, duration, distance, and pace. You can find more information about this here. Most Fitbit devices automatically recognize and record high-movement activities through the SmartTrack feature. To start, your device recognizes activities at least 15 minutes long.
Hope this helps.
