02-11-2023
03:41
05:05
DavideFitbit
02-11-2023
03:41
05:05
DavideFitbit
Is there any way to change the swipe order? They put notifications first if you swipe right an ECG if you swipe left. Two things I hardly ever use on my Fitbit.
I would like to have the timer the first thing to show up when I swipe right.
Hi, it's good to see you visiting the Community forums, @lalopez42.
Thank you for your inquiry regarding the option to change the way the apps are displayed on Fitbit Charge 5.
Unfortunately it's not currently possible to customize an existing clock face or the device interface, but I found a similar suggestion posted in the forums: Able to customize order of apps/stats on Charge 5.
You can vote for this existing idea, and keep in mind that you can also review the other clock faces available and change the clock face option to change the way the stats are displayed (not the apps, like notifications, exercise, ECG).
If you have a more specific idea, you can also post it in the Feature Suggestion board of the Community, since this section is regularly monitored by the team of developers. Make sure to post your idea including as many details as possible.
@lalopez42 I'm sorry, but there is no way to change the swipe order. The Luxe navigates like the Charge 5. I don't like it either.
Laurie | Maryland
Hi, @lalopez42 , thanks for sharing that idea! That is currently not possible, but I would recommend adding your vote and comments to this feature suggestion . The moderators monitor that board and pass on to the developers the most popular suggestions. The more votes the more likely a feature is to be implemented.
It's pretty wild to me that this suggestion has been vocalized for like two years and it still hasn't been implemented.
Welcome to the community forums, @HilltopSunset.
Thanks for taking the time to share your feedback and comments about this.
It's not always possible to implement features as fast as we'd like to see, but it's always helpful to vote for these ideas so the team can continue to track popularity and demand over time.
